The Axminster Woodturning Micro Handle is another piece of precision engineering from our own manufacturing facility in Axminster. Machined from a solid stainless steel bar it has a gently contoured grip with light knurling to prevent it slipping in the hand.
The business end has a 7.5mm bore to accept a range of small and miniature turning tools as well as other accessories. The tools lock securely into place with two grub screws.
The Axminster Woodturning Micro Handle provides plenty of mass which we have found a great advantage when turning. The weight helps you keep the tool on the rest and maintain the high level of control required for small and miniature work. Perfect for turning pens and small projects. Size 150mm long x 25mm diameter with 7.5mm bore.
Made in Britain Yes
Intended Use Gives a positive non-slip grip for woodturning Tools.
Web Attribute Set Woodturning Tools - Sets
EAN Barcode 5052511120574
