Bahco 1/4in Drive 26 piece metric socket set consisting of: 5 x Hex Sockets: 6, 7, 8, 10 & 13mm.1 x 60mm Hex Magnetic Bit Holder Quick Release.5 x Hex TORX Bits: TX10, TX15, TX20, TX25 & TX30.3 x Hex Phillips Bits: PH1, PH2 & PH3.3 x Hex Pozidriv Bits: PZ1, PZ2 & PZ3.4 x Hex Bits: 3, 4, 5 & 6mm.3 x Slotted Screwdriver Bits: 4, 5 & 6mm.1 x Bit Ratchet With 8mm Ring.1 x Adaptor. Always handy where professional bits and sockets are required. The bits and sockets are made from high performance alloy steel, with different finishes: Bits: Zinc phosphate. Sockets: Chrome. Ratchet: Plated. The box has round corners and can be easily stored in a pocket.
Bahco
Bahco 2058/S26 1/4" Drive Ratchet Socket Set, 26 Piece
| Web Attribute Set | Socket Sets |
| EAN Barcode | 7314151849276 |
