Bahco Box joint water pump pliers with two-component handles for maximum grip comfort. Made from high-performance alloy steel with a phosphate finish and are anti-corrosion treated. The pliers have 7 jaw positions and a gripping capacity of 35mm.
Length: 250mm
Head width: 40mm
Edge opening: 13mm
Edge thickness: 4mm
Web Attribute Set Plumbing Tools
EAN Barcode 7314150117154
