These shallow flute detail gouges are great for cutting coves and beads. Vibration is minimised by having more metal as support under the cutting edge. A fine fingernail-shaped grind gives very easy entry to the start of the cut. Fitted with a 317mm (12.1/2) long handle.
Made in Britain Yes
Size 2026-08-03 00:00:00 +0100
Gouge Type Detail Gouge Web Attribute Set: Woodturning Tools - Individual
EAN Barcode 5052511089659
