Sharpening and adding a burr to a cabinet scraper is made a lot easier by using a tool designed for the job. The Crown Burnisher is a traditional, good quality, Sheffield made tool. The polished HSS rod is a generous 150mm long by 9mm in diameter to give you smooth effortless controlled burnishing. The comfortable 130mm long handle is polished hardwood with a brass ferrule.
Made in Britain Yes
Web Attribute Set Scraper Burnishers
EAN Barcode 5052511088560
