The Ci7 solid carbide diamond shaped tip is 8.6mm wide. It fits the Micro Easy Detailer and Mid-Size Micro Easy Detailer.
​The standard carbide cutters provide a neutral rake, which is the angle of a cutter relative to its cutting surface. These cutters start sharp and stay sharper longer to reduce catches and blowouts.
​When one portion of the cutter eventually dulls, simply rotate to a fresh cutting edge and continue turning. When all edges are used, simply replace the cutter. More time for turning and zero time spent sharpening.
