The Easy Wood Tools Easy Micro Tools™ 3‑Piece Set brings together the essential tools needed for small‑scale woodturning, including roughing, shaping, and fine detailing.
The set includes a Micro Easy Rougher™, Micro Easy Finisher™, and Micro Easy Detailer™, making it ideal for working on pens, bottle stoppers, ornaments, and other miniature turning projects.
Each tool in the set features a replaceable carbide cutter and a flat‑profile bar that sits securely on the tool rest, making them easy to control and intuitive to use.
With no sharpening required, the Micro set is particularly suited to beginners or anyone looking for a simple, low‑maintenance system for small‑scale turning. The compact size of each tool allows for excellent control in tight or detailed work.
Together, the three tools provide a complete system for small turning projects. The Rougher™ efficiently removes material to establish shape, the Finisher™ refines curves and smooths surfaces, and the Detailer™ adds fine definition and decorative detail.
Used parallel to the floor at centre height, each tool remains stable on the rest, helping reduce catches and allowing for clean, controlled cuts. The combination of compact tool size and carbide cutters delivers predictable results, even on delicate or small‑diameter workpieces.
Easy Wood Tools’ long‑lasting carbide cutters hold an edge many times longer than HSS and are suitable for dry or green wood, as well as acrylics. With no sharpening needed, maintenance is simple — when the edge dulls, just loosen the fixing screw and rotate or replace the cutter.
The shaft is engraved with the corresponding carbide cutter reference number for easy identification.
Specifications
Set includes: Micro Easy Rougher™, Micro Easy Finisher™, Micro Easy Detailer™
Cutter types: Square, round, and diamond carbide cutters
Range: Micro (compact tools for small‑scale turning)
Bar profile: Flat section for stability on the tool rest
Handles: Hardwood with copper ferrules
Negative rake carbide cutters are available separately and are particularly effective on acrylics, polyester, and resin, helping to produce a smoother finish and improved control on delicate materials.
