The Faithfull Mastic Gun is built for strong, reliable performance, using a heavy‑gauge steel construction for added durability. Its large handle features ribbed finger grips, providing comfortable 360° control throughout use.
The ratchet mechanism includes a double‑spring system that delivers smooth, precise sealant flow with every trigger pull, and an instant release when the trigger is let go. It accepts all standard adhesive and sealant cartridges, and a convenient nozzle‑cleaning pin is integrated into the handle for easy maintenance.
Designed for versatility, the gun supports cartridges up to 425ml and features a 285mm barrel length.
Web Attribute Set Sundries
EAN Barcode 5023969265087
