A knife designed for work on wiring and nylon ties. The blade has two edges, a double bevelled straight edge and a single bevelled edge for cable stripping. The 33mm long blade is 1.5mm thick Japanese high carbon steel that has been hardened to 58-60 HRC. The handle and sheath are of extra durable PP plastic. The sheath features a unique method for attaching the sheath around a button on your work clothes, which means it does not loosen, but is easy to remove. The sheath fits just as well on your belt as on your buttons. If your belt is thick, cut away the small pin on the cover.
Hultafors
Hultafors ELK Electrician's Knife
| Web Attribute Set | Knives |
| EAN Barcode | 7317843800319 |
