The IRWIN Jack Universal 880 Triple Ground Hardpoint Saw is fitted with a high-quality C75 steel blade and features a unique Triple Ground tooth design offering up to 25% faster cutting performance than traditional double ground saws. The blade has a PTFE coating to reduce friction. The handle is a proven design, light and strong with an ultra sonic welded soft grip for increased hold and enhanced comfort. 90 and 45 degree angles integrated in the handle aid the user when marking out.
Jack Irwin
IRWIN Jack 880 UN Universal Hand Saw 550mm (22") Coated 8 TPI
| Web Attribute Set | Handsaws |
| EAN Barcode | 5706918975250 |
