The IRWIN Jack Universal 880 Triple Ground Hardpoint Saw is fitted with a high-quality C75 steel blade and features a unique Triple Ground tooth design offering up to 25% faster-cutting performance than traditional double ground saws. The blade is treated with a water-based lacquer providing 4X the added protection than conventional anti-rust agents. The handle is a proven design, light and strong with an ultrasonic welded soft grip for increased hold and enhanced comfort. 90°; and 45°; angles integrated in the handle aid the user when marking out.
Jack Irwin
IRWIN Jack 880 UN Universal Panel Saw
| Length | 550 mm |
| Web Attribute Set | Handsaws |
| EAN Barcode | 5706915052138 |
