Experience efficient and precise cutting with the KNIPEX BiX® Clever Pipe Cutter. This tool is designed to cut pipes quickly, cleanly, and without shavings. It fits comfortably in the hand and features a locking mechanism for safe transport. Ideal for cutting high-temperature plastic drain pipes and electrical conduits, this cutter works swiftly and effectively. It can also be used to cut sealing sleeves during final assembly, close to the wall, and is standard-compliant. The rotatable knife block allows for versatile cutting, with the blade positioned in the middle for plastic pipes and on the outside for sealing sleeves. Additionally, the tool includes two spare blades integrated for convenience.
Length 250 mm
Web Attribute Set Pliers
EAN Barcode 4003773012023
