The KNIPEX DoubleJoint Control Cabinet Key is a versatile tool designed with four different zinc die-cast key profiles and a magnetic bit adapter for 1/4 bits. This key is suitable for a wide range of locking systems in electrical engineering, the supply of gas and water, air conditioning and ventilation systems, industry, and technical installations in buildings.
Includes square (5.0-8.0mm), double-bit key (3-5mm), and triangular (7.0-9.0mm) profiles.
Web Attribute Set Electricians Tools
EAN Barcode 4003773083085
