The 90° Corner Clamp with Automaxx® Auto-Adjust Technology delivers fast, precise right angle clamping for woodworking projects. Ideal for assembling boxes, cabinets, drawers, and cases, it ensures tight, accurate 90° joints with pocket hole screws, wood screws, or nails.
Built with durable all metal construction, the clamp features cast aluminum pads and V-wedge jaws that grip inside and outside faces to hold pieces perfectly at 90°. Built in edge stops keep materials flush, while cutouts allow you to drive pocket-hole screws without removing the clamp.
Simply squeeze the handles and Automaxx® technology automatically adjusts to materials up to 1 thick for consistent clamping pressure - no need to adjust manually. A padded ergonomic grip ensures comfortable handling.
Web Attribute Set Quick Clamps
EAN Barcode 647096807535
