An exceptionally strong tool, with a multitude of uses. The claw is used to remove nails, the flat surface immediately behind the claw can be struck with a hammer to help drive the claw under the nail head. This flat surface also doubles up as a hammer itself. 300mm long it develops plenty of leverage to remove stubborn nails. Opposite the claw is a wide gently curved spatula shaped end, use to gently pry or as a scraper. The shaft features a ring to attach a lanyard. A great tool for those involved in remodelling, where minimising damage means saving time and money.
Ice Bear
Mokuba Japanese Reform Bar - 300mm
| Web Attribute Set | Wrecking & Pry Bars |
| EAN Barcode | 4960408008700 |
