The Monument 1715 aluminium bodied Autocut is designed to cut 15mm copper pipe. Its compact size allows it to work in tight spots and awkward places, where pipes are close to a wall for example. It cuts in one direction ensuring you get the perfect cut edge, every time, helping to solve leaks and uneven joints.
It will only cut the exact size of copper pipe specified and is NOT for use on stainless steel.
Size 15mm.
Made in UK
