This small tool is an absolute essential when it comes to deburring the ends of copper tubing. It is equally effective on aluminium, brass, PVC and soft steel. The 365F is double ended, one side for internal and the other for external deburring up to 35mm diameter. Three hardened steel blades ensure a quick, clean and even result. Deburred pipe ends minimise the risk of leaky joints especially if using push fit couplers. Tough moulded body, only 50mm tall fits into any tool bag. The Monument 365F is a must for any plumbing job.
Manufacturer Part Number 365F
Web Attribute Set Plumbing Tools
EAN Barcode 5015375003650
