Shape up with the two-handled Japanese saw rasp. The 260 x 30mm blade is double sided, coarse one side and fine on the other. The open lattice of the blade eliminates clogging. Tempered steel cutting teeth, use on wood, laminates, non-ferrous metals, plastics, gypsum board etc.
Tools from Japan
Shinto Japanese Two-Handed Saw Rasp - 260mm
| Grade | Coarse & Fine |
| Rasp Type | Saw Rasp |
| Web Attribute Set | Hand Rasps Rasp Length: 260 mm |
| EAN Barcode | 4986744631013 |
