A replacement or spare blade for the Shokunin 180mm Atsuba Japanese saw. It features razor sharp crosscut teeth for fast accurate cuts. Curved blade tip allows a cut to begin in the centre of a panel. Impulse hardening of the cutting edge greatly increases the durability of the teeth. It cuts a variety of materials: wood, plywood, laminates etc. Easily changed by simply loosening the locking screw on the handle, remove the old blade and replace it with the new.
Shokunin
Shokunin Blade for Japanese Atsuba Saw - 180mm
| Blade Thickness | 0.50 mm |
| Additional Accessories | Yes |
| Web Attribute Set | Japanese Handsaws |
| EAN Barcode | 5052511101894 |
