The Shokunin Dozuki Super Hard Saw Blade is a replacement blade for the Shokunin Dozuki Super Hard Saw. This blade features impulse-hardened teeth that ensure exceptionally fine crosscuts, while the rustproof nickel plating enhances durability. The blade's 0.3mm thickness and 1.5mm tooth pitch allow for smooth, effortless cuts, leaving a clean finish with minimal effort. The stiff spine provides stability, enabling a 50mm depth of cut, making it ideal for intricate woodworking tasks.
Blade Thickness 0.30 mm
Web Attribute Set Japanese Back Saws
EAN Barcode 5052511134007
