STANLEY® CUSHION GRIP™ Screwdrivers are constructed with an ergonomic, bi-material handle. The unique 8-sided octagonal handle shape allows better grip, control and torque transfer. The blades are engineered from high-strength, chrome vanadium steel to reduce the chance of tip breakage. Manufactured to the strictest standards and specifications. Suitable for demanding high torque applications. This 6 piece set contains: 3 x Slotted Screwdrivers: 3 x 100mm, 4.0 x 100mm, 5.5 x 100mm. 3 x Phillips Screwdrivers: PH0 x 60mm, PH1 x 100mm, PH2 x 100mm.
Stanley
Stanley CUSHION GRIP™ Screwdriver Set, 6 Piece
| Manufacturer Part Number | 0-62-151 |
| Web Attribute Set | Screwdriver Sets |
| EAN Barcode | 3253560621513 |
