The Stanley FatMax®; Slotted tip screwdrivers have a chrome vanadium steel bar which allows high torque and reduces the risk of tip breakage, and the handle is moulded directly to shaft for a virtually unbreakable bond which gives long life and durability. The soft grip handle provides great grip and reduced fatigue in use. Colour coded for easy identification of the right tip type for the application. The smooth domed end offers fast, comfortable spinning action and the large diameter handle offers higher torque when driving wood screws. Parallel tips are ideal if the screw needs to be driven below the material surface.
Stanley
Stanley FatMax® Slotted Screwdriver
| Manufacturer Part Number | 65008, 64979, 64978, 64983, 65017, 65093, 65094, 65096 |
| Blade Length | 100 mm |
| Tip Size | Slotted 3.0mm |
| Web Attribute Set | Screwdrivers General |
| EAN Barcode | 3253560650087 |
