Effortlessly cut plastic pipes or hose up to 28mm diameter. The Stanley 0-70-450 Plastic Pipe Cutter will give you a clean, square cut, ready for connection. No messing, cleaning or deburring ends from a saw cut. The super sharp stainless steel blade leaves a clean finish. The cutter features a tough moulded body in easily spotted bright yellow. The 0-70-450 can be used on plastic pipe, garden hose, electrical conduit, tile trims etc.
Manufacturer Part Number 0-70-450
Web Attribute Set Plumbing Tools
EAN Barcode 3253560704506
