Thor dead blow hammers have coated die-cast aluminium alloy head with rubber grip and screw-in faces. The hollow die-cast head is partially filled with steel shot to add to the weight, prevent rebound and deliver dead blows of maximum force. Thor dead blow hammers are ideal as a multi purpose striking tool and are ideal for sustained and effective blows without recoil. They are commonly used in most assembly / fitting applications including engineering, toolmaking, shopfitting, partitioning and double glazing. Replacement faces are available.
Hammer size \ weight 63 mm - 1,85kg (4lb 2oz)
Web Attribute Set Soft Faced Hammers
EAN Barcode 5012936202019
