Thor copper hammers have a malleable Iron head fitted with two cylindrical faces of pure electrolytic copper on a wooden shaft. The malleable Iron head provides the weight for the blow and the the Copper faces also provide weight whilst transferring the force to the item being struck without fear of damage. Ideal where a heavy blow is required combined with a relatively small striking area. These copper hammers have faces that are designed to wear and can be easily replaced as spare faces are available. They are used as a general-purpose soft-faced hammer in automotive and general engineering for assembly, repair and maintenance.
Thor
Thor 312 Copper Hammer - 38mm, 1,260g
| Hammer size \ weight | 38 mm - 1.26 kg (44oz) |
| Web Attribute Set | Soft Faced Hammers |
| EAN Barcode | 5012936031206 |
