The TRACER 5.2mm Plastic Tough Pencil is a heavy-duty construction pencil designed for professional tradespeople who require a reliable marking tool for demanding working environments. Featuring a robust ABS body and a durable 5.2mm lead, this tough pencil is suitable for marking a wide range of materials, including wood, metal, concrete, brick, plastic and tile. Its debris-resistant push button helps maintain smooth operation in dusty jobsite conditions, while the anti-roll clip helps prevent the pencil from moving when placed on work surfaces. Combined with a knurled grip for improved comfort and control, this professional marking pencil is designed to deliver accurate, dependable performance throughout the working day.
The pencil is supplied with a TRACER site holster, providing convenient access and secure storage while working on site. The holster features an improved pocket clip for attaching to workwear, an integrated sharpener for maintaining a precise point, and an identification symbol for easy tool management. A gravity-fed lead mechanism allows quick lead adjustment and replacement, helping to minimise downtime and keep work progressing efficiently. Together, these features create a practical marking solution for builders, carpenters, electricians, plumbers and other trade professionals.
TRACER is a specialist brand focused on professional marking and measuring tools for the construction industry. Known for durable, jobsite-ready products and innovative design features, TRACER develops tools that help tradespeople work with greater accuracy, efficiency and confidence across a wide range of applications.
Web Attribute Set Marking Pencils
EAN Barcode 9341231068560
