The TRACER ProMitre is an eight-in-one multi-function marking tool, which is ideal for a wide range of construction, carpentry and joinery applications. The ProMitre enables users to accurately measure, mark and transfer angles onto beams, pipes, boards and other three-dimensional workpieces. It improves accuracy and consistency when marking out cuts, joints and installations, making this the perfect professional layout tool; plus its robust construction makes is suitable for use in demanding workshop and jobsite environments.
The tool incorporates eight practical measuring features, including pre-set angle guides from 10° to 80°, additional reference angles at 30°, 45° and 60°, and a vertical angle scale for marking any angle between 0° and 90°. A series of 61 parallel marking guides in 1mm increments provides precise layout marking, while integrated 0-60mm horizontal and 0-155mm vertical rulers support accurate measurement and transfer tasks. The ProMitre also includes dovetail templates and depth scales, making it particularly useful for marking dovetail joints, woodworking projects, cabinetry, kitchen fitting and general joinery work.
TRACER is a specialist manufacturer of professional marking and measuring tools trusted by tradespeople across the construction industry. Known for innovative, jobsite-focused designs, the brand develops practical tools that help improve accuracy, efficiency and productivity for professional users.
Web Attribute Set Mitre Squares
EAN Barcode 5060668272244
