These adaptors join two UJK Progrip Guide Clamps back to back. Using a pack of adaptors you can turn two pairs of clamps into an effective holding device to grip panels of sheet material across the top of your bench. The lower clamp grips your bench, while the upper clamp holds the workpiece. Adaptors supplied as a pack of 8.
Web Attribute Set Routing Jig Accessories
EAN Barcode 5052511094134
