The Vitrex Torque Master Power Tile Cutter is capable of cutting ceramic and porcelain, wall and floor tiles. The continuous rim diamond cutting blade ensures a clean cut. Its 450W Hi-Torque geared motor gives maximum cutting performance. The blade is water cooled for dust free cutting and fitted with an adjustable height splash guard. The splash guard has a quick release for plunge cuts. The water is continuously recirculated keeping the blade cool throughout the cut. A straight fence is provided along with an adjustable mitre fence for angle cuts from 0 to 45. The generous sized top provides plenty of support for large floor tiles. The right hand top section flips up for cutting 22.5 and 45 mitres along the tile’s edge.
Max Depth of Cut @ 45º 17 mm
Max Depth of Cut @ 90º 25 mm
Overall L x W x H 375 mm x 365 mm x 180 mm
Power 450 W
Rating Home Workshop
Table Size 375 mm x 365 mm
Blade Diameter 110 mm
Web Attribute Set Tile Cutting Machines
EAN Barcode 5011204603749
