This replacement blade secures to the handle by a simple screw. The diamond ground teeth cut on both the pull and push stroke, producing fast and clean results. The blade has impulse hardened teeth and electro-less Ni-P plating for greater wear resistance and increased corrosion protection. The 270mm long blade is replaceable; it is 0.70mm thick with a 2.4mm pitch.
Blade Thickness 0.70 mm
Web Attribute Set Japanese Handsaws
EAN Barcode 5052511094370
