This extra fine dozuki saw blade easily clips into the handle of our Small Dozuki Saw. It has a very fine tooth pitch of 25tpi and a blade thickness of only 0.30mm. With its impulse hardened Japanese style teeth, it is perfect for intricate woodwork requiring the utmost precision. This blade produces very clean cuts in softwoods and minimising chattering when cutting a thin board.
Z-Saw Blade for Japanese Small Dozuki Panel Saw - Fine 150mm
| Blade Thickness | 0.30 mm |
| Tooth Pitch \ tpi | 1.00 mm \ 25 tpi |
| Length of Blade | 150 mm |
| Saw Blade Type | Crosscut |
| Web Attribute Set | Japanese Back Saws |
| EAN Barcode | 4963041071049 |
