IMPORTANT: If you would like more information on this JSP PowerCap® Infinity® respirator before purchase please contact our customer support team on 03332 406406.
The JSP PowerCap
The system uses a powerful, lightweight, battery powered fan to draw air through the filters and then blow clean air down over the user's face. The supplied Li-Ion battery delivers clean filtered air for up to 8 hours on a single battery charge. This positive pressure system allows the user to breathe normally, eliminates misting inside the face shield and accommodates facial hair without any loss in protection. The high capacity HEPA filters coupled with aerodynamically optimised pre-filter covers ensure the PowerCap
Real time diagnostics monitor the system twice a second. During periods of high respiratory demand the system compensates and maintains a positive pressure inside the respirator. The respirator provides accurate, dynamic feedback on battery and filter condition via a heads-up display and audible notifications.
The integrated face shield protects eyes and face from impact, dust and debris while providing a clear wide field of vision. The visor offers impact protection at speeds of up to 270 mph (tested using a 6mm steel ball bearing). The visor has K rated anti-scratch coating and a replaceable peel-off visor protector to prolong its life.
PowerCap
Respiratory protection: TH3, with a Nominal Protection Factor of 500 (UK APF {Assigned Protection Factor} 40), the highest possible rating in the EN 12941:1998 + A2:2008 standard.
Full-face protection: Optical class 1 visor conforms to EN166.B.
Head protection: Conforming to: EN397 (European Standard). ANSI/ISEA Z89.1 (American National Standard). CSA Z94.1 (Canadian Standard). GB2811 (Chinese Standard).
Please note as this is a Health and Safety respiratory item, we cannot accept items for a refund once the packaging seal is broken and item has been worn.
