These HSS spiral drills have a CENTROTEC bit holder which is suitable for use in all CENTROTEC quick change chucks or a standard drill chuck. The high-speed steel drill bit is suitable for drilling wood, plastic and non-ferrous metals. Supplied with CENTROTEC holder and 2 drill bits which are easy to interchange with a hex key. Available in 4 sizes; 3mm, 3.5mm, 4mm or 5mm.
Festool
Festool CENTROTEC HSS Twist Drill Bit & Bit Holder
| Manufacturer Part Number | 493421 |
| Drill Bit Diameter | 5.0 mm |
| Web Attribute Set | Festool Centrotec |
| EAN Barcode | 4014549050187 |
