The majority of tools are ferrous metal, which makes a magnetic tool rack an invaluable and versatile storage option.
Heavy duty permanent magnet assemblies hold tools or metal parts firmly and securely in place. They are an easy way to group tools like drill bits, pliers, spanners or chisels. You can change the arrangement at any time. A magnetic rack is especially useful for holding small items.
Each strip measures 330mm in length; fixing tabs with screw holes ensures positive and secure mounting. Wall mounted over your workbench, your most frequently used tools are immediately to hand. A magnetic tool rack frees up much needed space, keeping benches free of clutter. Like a magnetic kitchen knife rack, these will keep sharp edges out of harm’s way.
Not just for walls, the rack is as effective mounted on the underside of a cupboard or the underside of a benchtop. You can increase existing storage capacity by fixing a rack on the inside of a cupboard door.
The racks have a sufficiently strong magnetic force to keep the tools in place and easily to hand.
Web Attribute Set Tool Holders & Storage Hooks
EAN Barcode 5052511119752
