Faithfull Cam Buckle Tie-Downs are ideal for firmly securing loads quickly and efficiently. These quick-release tie-downs are designed for use when transporting lightweight items and are perfect for use with car roof racks. Manufactured using 100% soft polyester webbing and in accordance with EN 12195-2, these tie-downs are extremely hard-wearing, durable and robust. Cam buckle straps are efficient and quick to use, the webbing is simply pulled through a self-locking cam buckle to the desired tension. Releasing the load is easily achieved by pressing down on the quick-release lever at the rear of the buckle to release the tension. A protective tab prevents scratches.
Specification:
Length: 5m
Width: 25mm
Breaking Strain: 200kg/200 daNMax.
Working Load: 100kg/100 daN
Please Note: weight of cargo must not exceed the working load limit.
