Ice Bear
Japanese Solid Forged Professional Secateurs
SKU: 701836
€68,00
  • Professional grade bypass shears
  • Hand forged and tempered
  • Firmly attached return spring between the handles
  • Clunky bottom catch with positive action to keep the shears closed N.B. To buy this product you must be aged 18 years or over. We will verify your age before despatching the order and this might involve us contacting you for proof of age. The product must also be delivered to, or collected by, a person 18 years or over.
These are professional grade bypass shears, hand forged and tempered, with beautifully ground and polished blades and a razor-sharp edge. They feature a return spring firmly attached between the handles (a spare is provided but we aren't sure what you are going to do with it). A clunky catch at the bottom has a positive action keeping the shears closed when not in use. The shears are simple, sharp and strong with well-shaped, smooth handles, very comfortable to hold and the action is smooth and positive, resulting in a clean and efficient cut. If you're looking for a quality garden tool, you need look no further than this one. This may be the only pruning shear you'll ever need.
Web Attribute Set Pruning
EAN Barcode 4560272501538
