A set of two 4,000 grit waterstones. Firstly, a 108 x 63.5 x 16mm block with 5 shallow rounded grooves on one side for sharpening the bevels of a wide range of sweeps of carving tools, the reverse side and edges can obviously be used for flat tools. Secondly, a small slip stone 63.5 x 38mm tapered with two round edges 3 x 6mm radius for inside small tools etc. Full instructions in Japanese on the reverse of the pack, luckily the pictures are easy to follow!
Grit 4000
Web Attribute Set Japanese Water Slip Stones
EAN Barcode 4963188108233
