UJK
UJK Backstop
SKU: 105367
£9.68
£8.07 Excl. VAT
  • Use on any multifunction table with 20mm holes at 96mm centres
  • CNC machined from durable, HDF Valchromat
  • Useful stop or assembly aid
  • 200mm long x 30mm wide x 20mm thick
  • 3 dog holes allow straight or diagonal placement
  • All 20mm holes are chamfered
  • Made in the UK
The Backstop is part of the UJK Cam & Wedge set available separately. The backstop has three dog holes; two spaced at 96mm for lateral or longitudinal positioning on a multifunction table and a third allowing diagonal placement. The UJK Guide Pups with their 12mm projection are the ideal companions.
On its own, it makes a useful planing stop etc. Together with a second backstop placed at 90 or diagonally at 45 it can form a useful assembly jig.
It is CNC machined from durable, 20mm thick HDF Valchromat; 200mm long by 30mm wide.
Valchromat is certified by the Pan European Forest Council (PEFC).
Made in Britain Yes
Intended Use Used in conjunction with dog holes to hold work to a workbench.
EAN Barcode 5052511108770
