The Backstop is part of the UJK Cam & Wedge set available separately. The backstop has three dog holes; two spaced at 96mm for lateral or longitudinal positioning on a multifunction table and a third allowing diagonal placement. The UJK Guide Pups with their 12mm projection are the ideal companions.
On its own, it makes a useful planing stop etc. Together with a second backstop placed at 90
It is CNC machined from durable, 20mm thick HDF Valchromat; 200mm long by 30mm wide.
Valchromat is certified by the Pan European Forest Council (PEFC).
