UJK
UJK Double-Sided Tape
SKU: 102795
£7.68
£6.40 Excl. VAT
  • Bonds to most materials even rough surfaces
  • Very high initial tack, high initial bond and a high shear resistance
  • Hand-tearable with paper carrier, easy to use
  • 19mm wide x 50m long
Manufactured by tesa UJK double-sided tape is quick and easy to apply. It will bond to most materials like wood, metal and plastics plus paint, varnish and similar surfaces. It is resistant to extreme temperatures, chemicals and solvents, humidity and UV radiation. The thick layer of adhesive bonds extremely well, even to rough surfaces. It has a very high initial tack and bond, and a high shear resistance. This double-sided tape, which you can tear by hand, consists of a silicone coated paper carrier and synthetic rubber adhesive. Double-sided tape is a truly useful item to have in the workshop or in the home. You will soon find it has a myriad of uses. Size: 19mm wide x 50m long.
Web Attribute Set Packaging Tools and Tapes Width x Length: 19 mm x 50 m
EAN Barcode 5052511073474
