High quality, HSS Co8 drill bits made to DIN388, with a long life as they have a TiN coating. The wide flute design is ideal for good chip evacuation and the point is designed to maximise self-centring. They can be used on a wide range materials including cast steel alloyed and non-alloyed, grey cast iron, graphite, malleable cast iron and woods. When used with cutting fluids, will drill stainless steels and titanium.
Axminster Jobber Drill Bits
| Drill Bit Diameter | 6.8 mm |
| Overall Length \ Working Length | 109 mm 69 mm |
| L1 | 69mm L2: 109mm Drill Bit Dimensions: L1 69 mm L2 109 mm Web Attribute Set: Drill Bits |
| EAN Barcode | 5052511106905 |
