Bosch
Bosch HSS Cobalt ProBox Drill Bit Set 1-10mm 19 Pce
SKU: 113986
€53,00
  • Long lasting wear resistant HSS Cobalt
  • Fully ground with 135 degree tip angle
  • Drill; alloy and hardened steels, cast iron, titanium etc
  • 1-10mm in .5mm steps
  • Supplied in robust case
This Bosch set is intended for use on alloy and hardened steels, cast iron, titanium and many other really tough, hard-to-drill materials such as stainless steel. Also suitable for hard and soft woods, manmade boards and plastics. Cobalt alloy and fully ground HSS provides wear resistance and heat protection. Two cutters and two flutes remove chips quickly to make the bits last even longer. Its cylindrical shank is compatible with three-jaw drill chucks. Manufactured to DIN 338, drill bit Type N (flute angle) with a 135-degree tip, diameter tolerance h8.
This 19 piece set has size range from 1-10mm in .5mm steps. Supplied in a robust protective case.
Web Attribute Set Drill Bit Sets
EAN Barcode 3165140689786
