UJK
UJK StepPower HSCO Drill Bit Set 19 Piece
SKU: 112956
€155,00
  • Set Contains 19 drill bits from 1mm to 10mm in 0.5 increments
  • Suitable for metalwork and high-precision woodworking
  • Contained in a durable plastic storage case
  • Multi-Step Drill Design for precision and effortless drilling
  • Unique step geometry ensures material is gradually removed
  • Split Point Geometry for precise centring and easy cutting
  • High wear resistance and durability
  • 3-Flat Shank prevents slipping in the chuck
When it comes to drilling, precision and performance are paramount. The UJK StepPower HSCO Drill Bits are engineered to deliver exceptional drilling performance, making them an indispensable tool for both metalworking and fine woodworking.
Primarily designed for metalworking, but their precision and sharpness also make them effective for hardwoods. Created with a unique multi-step design and a 118° point geometry, these drill bits ensure precise centring and effortless cutting. This innovative design not only enhances accuracy but also reduces splintering and tear-out, providing a smooth finish.
The UJK StepPower HSCO Drill Bits are made from 5% cobalt high-speed steel (HSCO), offering superior wear resistance and durability. This robust material ensures that the drill bits can withstand the rigours of heavy-duty use, maintaining their sharpness and effectiveness over time. The 3-flat shank design prevents slipping in the chuck, guaranteeing exact circular holes every time.
Whether you're a metalworking, woodworking or both, the UJK StepPower HSCO Drill Bits are designed to meet your needs with unparalleled efficiency.
Set Contains 19 drill bits: 1mm, 1.5mm, 2mm, 2.5mm, 3mm, 3.5mm, 4mm, 4.5mm, 5mm, 5.5mm, 6mm, 6.5mm, 7mm, 7.5mm, 8mm, 8.5mm, 9mm, 9.5mm and 10mm, housed in durable plastic storage case.
Intended Use For drilling a variety of materials, steels, cast iron, graphite & wood.
Web Attribute Set Sheet Metal Drilling
EAN Barcode 4049844505926
