Experience exceptional cutting performance with the KNIPEX CoBolt® Compact Bolt Cutters featuring a multi-component grip with a return spring. These cutters feature a lever action mechanism that guarantees an extremely favourable lever ratio with low friction, resulting in cutting performance that is 20 times higher than the hand force applied, requiring 60% less effort. Ideal for cutting piano wire, soft solid wire, bolts, nails, rivets, and screws, these cutters are induction-hardened and equipped with precision cutting edges. The edge hardness is approximately 64 HRC, providing added strength and durability. The lever action ensures exceptional cutting performance with minimal physical effort.
Knipex
KNIPEX CoBolt® Bolt Cutters Multi-Component Grip with Spring 200 mm
| Web Attribute Set | Wire & Cable Cutters |
| EAN Barcode | 4003773067078 |
