The 55 spear shaped blade with its double bevel means this knife is usable left-handed or right-handed. The back of the blade is flat allowing the knife to run along a square’s blade or straight edge. A wooden scale on each side attached with steel rivets form a comfortable handle. A knife line is far more precise than a pencil line. The cut line forms a register for a chisel or saw resulting in work that is more accurate. Overall length 150mm, blade length 50mm.
Web Attribute Set Marking Knives
EAN Barcode 5052511063918
