A quick drying pigmented acrylic lacquer to give the smooth luxurious look of Ebony in a hardwearing satin black coat. After good preparation apply either Chestnut's Acrylic or Cellulose Sanding Sealer as per the instructions. When this has dried thoroughly apply several thin coats of the Ebonising Lacquer at ten-minute intervals. This will be touch dry in ten minutes but should be allowed 24 hours to cure fully before use or further enhancement with Chestnut Acrylic Gloss Lacquer.
Chestnut
Chestnut Ebonising Lacquer - Aerosol 400ml
| Coverage | 6 m to 8 m per litre |
| Application Method | Spray |
| Drying Time | 20 minutes |
| Size | 400ml |
| Web Attribute Set | Lacquer, Paint & Varnishes |
| EAN Barcode | 5060095030271 |
