This finish will give protection against both heat and water. It can be used alone or, for better results, over a cellulose based sanding sealer. Several thin coats provide a superior finish. Quick drying due to cellulose base. The melamine dries to a gloss finish and can then be matted using 0000 Steel Wool, or brought to a gloss by applying wax with a pad of 0000 Steel Wool and buffing to a shine.
Chestnut
Chestnut Melamine Gloss Lacquer
| Coverage | 8 m to 10 m per litre |
| Application Method | Brush Rag or Cloth Spray |
| Drying Time | 5 minutes |
| Clean Up | Cellulose Thinners |
| Available Sizes | 500 ml |
| Web Attribute Set | Lacquer, Paint & Varnishes |
| EAN Barcode | 5060095030080 |
