Polyvine
Polyvine Multi-Surface Lacquer
SKU: 506587
€26,00
  • Crystal clear finish, apply to may surfaces
  • Tile, Metals (ferrous and non ferrous), Ceramic, Laminate
  • Plastics and Glass, Paint and interior wood
  • High Build for a deeper finish
  • Stain, Heat and water resistant finish
  • Available in either gloss or satin
  • Can be used as a Primer N.B. To buy this product you must be aged 18 years or over.
A multi-purpose lacquer that gives a hard durable finish for exterior and interior use. Bonding to many surfaces with crystal clear results providing a water, heat and stain resistant finish. This Quick drying lacquer is easily sanded. Can also be used as a multi surface primer. Suitable for use on; Tiles, ferrous and non‑ferrous metals, laminate, ceramic, plaster, decorative finishes, murals, glass, plastics, interior wood, and previously painted surfaces.
2 - 3 coats recommended, drying time approx. 20 minutes depending on surface.
Coverage 15 m to 20 m per litre
Application Method Brush
Drying Time 1 to 2 hours
Clean Up Water
Available Sizes 1 litre
Web Attribute Set Lacquer, Paint & Varnishes
