Used as as an aligning or jointing biscuit, the 7mm thick flat Bisco is designed to work with the P-system groove produced by the Zeta or CNC system, providing alignment for assembly and greater shear strength, it can be glued in place if required. The
Bisco is a flat 7mm plastic biscuit and is available in two sizes.
Bisco P-14 is 65mm x 27mm or Bisco P-10 is 52mm x 19mm
Pack Quantity 300
Web Attribute Set Biscuit Jointer Accessories
EAN Barcode 7640129666751
