Axminster Woodturning
Axminster Woodturning Faceplate 50mm - 3/4" x 16 tpi
SKU: 500090
€14,00
  • 50mm diameter faceplate
  • Maximum accuracy and perfect balance
  • Circular grooves aid blank centring
50mm diameter faceplate is CNC-produced for maximum accuracy and perfect balance. The timber mounting holes are fully countersunk on the rear face and lightly countersunk on the front face to ensure proper seating of the timber; circular grooves are provided to aid the centring of the blank on the plate. Please note that the 50mm faceplate is available with the 3/4 x 16tpi thread only.
Made in Britain Yes
Thread Size 3/4 x 16 tpi
Intended Use Plays a crucial role in securely holding the workpiece on a lathe.
Web Attribute Set Live Tailstock Centres
EAN Barcode 5052511022168
